Just Plain Stupied
Finally sbseee time. This is going to be good.
To make wrecking-crew happy just put in the good ol' SBC, paint the valve covers FoMoCo blue and stencil on a white oval logo. Problem solved :icon_thumby:
ahhhhh SBC!!! More PoWa!!!!!!!!1 WHAAAAaAAAAAAaAAA
I'd like to read you guys a quote......................HYENNAS !!!!!!!!!......................................
Just a bit of input.
Have you checked the timing?thanx for dbl-checking on me....yep....not only did i do the timing check(which was at 35*!!!), but i rotated the disty both ways to see if there was a sweet spot(which was at 20* with the shorting bar unplugged)
I found a eec/ecm/emc2 test book at the liberry....I'll test the ee...computer in the morning to see if it's fried....since all the sensors tested good yesterday....
Annnnnna ifa ita isa frieda..........S-aa B-aa Seeeeee-aa time !!!!!!(i speaka italian too)
But I will be depending (No... not DEPENDS diapers) on you guys to provide the co-rect motor mount part no.'s to make this as pai....brainless as possible to counter-act the V.A. drugs......Wa....no....seriously!!!!!!
im just sayin that to mess with blackwidow. i dont mind seeing a sbc in a ford.
Either way he should do that, dress up the SBC to make look like a FoMoCo motor:D
Yep.....the stragedegy...straydogey....thing is....to conceal the rear mounted distributor to trik the die-hard fomoco guys.....being from the New Orleans area, I figured one of these over the distributor would be appropriate:
;brownbag;
Then, to draw attention away from Da Bag....I would JB weld a fomoco distributor near the water pump by sawing the lowereererer part of the shaft off....
But first.....I;m waitin on some pics of sbc motor mounts installed, so the chevy part of my wittle brain can start processing the info.....
Pics please: (place here.....and hurry....i'd like to have this done by...ohhhh....yesterday afternoon)
EDIT: forgot tolog out again last nite!
you could hide the dizzy with a blower.:headbang:
:icon_bounceblue:i feel the need.... the neeed for Speed!
