just did m5od swap... questions
I'll check it out. You don't have any ECU's right
I have a 94, that I think is for an EGR system, I have another one in the garage that I have to go look at, but the system acts funny when it is plugged in, so I don't know that it is OK.
I will check the numbers on it in the morning and if it is a good number I'll take it up to Williamsport and see if Brinker's truck will run with it in.
Alright man if so how much
I think I have $150 in it. Say $160 shipped if it works and is the one you need.
Alright man. The UC. ecu what's that one for
The suffix in the part number indicates the revision. In the case of these computers it is probably a software level of some sort.
I don't know exactly what each one indicates.
Alright man. You been a big help. Any of the ECU's you stated should work. Correct?
If you KNOW that you DO NOT have EGR (easy to tell) you also do Not have "SEFI"
The computer I always recommend is one where the BIG letters to the right of the label
are "ANY1", this number is a more relevant number.
This is specifically a 1993 Explorer manual transmission PCM (Powertrain Control Module)
