as johnnyo said, newer 3.0's have a little plastic funnel that keeps most of the oil off the starter. i always get my filter from the bottom. partly because im working on a vehicle hoist, partly because i only change my oil after its up to temp...and i still have the scar from the last time i tried to snake my wrists in past that hot exhaust manifold from the top.
heres how i flush my vehicles cooling system:
napa sells a chemical flush that works wonders for removing rust and scale. its made by macs, comes in a blue bottle, and is in powder form. they also sell a flush thats in liquid form...dont confuse the two.
while your at napa, pick up a new thermostat and gasket (cheap).
when you get home, as per the instructions on the bottle, drain your cooling system. while its empty, remove your t-stat (install the housing using the old gasket...it should seal well enough for your purpose).
flush the system with water then drain and refill with water plus the flush. let the truck circulate this mixture at idle for 30 minutes. drain, fill/flush, then drain and install your new t-stat and gasket. refill with no more than a 50/50 mix. if you live in more temperate climate, more water is better. i usually run 75-80% water and 25-20% antifreeze.
i know it sounds like kind of a long drawn out proceedure...and it kind of is. best to save it for a weekend when you can wait for the truck to cool between flushings.
