It's on now! The lift continues! and a Ford funny!
looks good, glad to see someone else using those "lowering" shackles, i plan on using them on my BII, but I wasnt sure if they were any good
i think the sploder leaves will make it perfect
Yeah, I'm pleased with them! No those are not F150 rims, 150 rims won't fit, they are 5 5.5. These are 5.45 jeep rims.
They are called 'lowering shackles' because they are intended for a chevy pickup, in which the rear shackles/hangers are the other way around. So they will drop a chevy, but lift a ford.
Oh, I meant to mention there is one side effect, the rear end is noisier now when I turn and go over bumps I guess cause it is tight. I sprayed it down with PB Blaster to try quite it down. It helped a little, but I guess it will bet better as it settles.
i dont know if i asked you this before but what size ar those tires? 31 10.5?
Looks good man, like the old school chrome spokes, don't see 'em around much anymore.:icon_cheers:
I think they are Chevy mirrors, they where on it when I got it, there is a access hole in the bottom, I assume you pop that out and there is a bolt up there you loosen?. Next trip to Pull Apart, I'm getting the stock ones back on and those are gone!
No. They will lift a Ranger/B2. Any fullsize Ford, they will lower.
