Issue with DRL staying on while truck is off – 96 Mazda B4000 4x4
Hermly
💻 TRS Socials
Firefighter
Southern Alberta
AB - CAN
Vehicle
Drive
You ain't stuck till you can't move the old girl.
Last night the wife mentioned my headlights were on, when I went out to my truck my headlight switch was in the off position and the key was out of the ignition.
My hi beam indicator was lit up on the dash, I fiddled with the both light switch and the hibeam switch and didn’t solve anything, and ending up unhooking the battery for the night.
Today I pulled the DRL fuse in the engine bay electrical box and no longer have the high beam light on my dash. Just wondering if anyone has come across this before?
There was also a moment where after disconnecting the battery and closing the hood the lights turned on again, but I’m not entirely sure that has anything to do with my other issue.
It sounds to me like you have some harness degradation. When you closed the hood, you got lights again for a second. That suggests to me that a positive wire is bared, and when you closed the hood the cable made contact with the body.
No the battery thing is weird and likely not connected, because I had the negative cable pulled off and tucked down beside the battery, and then when I closed my hood the lights came on again.
I haven’t had a dry day here to dig into the main issue yet, but after thinking about you might be on to something with the harness
