James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
I don't know what this crossmember is called. It protects the steering. It's pretty thick and it's welded to the frame. Can I safely put tow hooks there or am I way better off to attach them more by the bumper mounts where the straps would be pulling more directly on the frame?
Just looks like the 2 holes are spaced about right and you could fit a hefty eye bolt in there. Question is whether it would just pull the thing off etc. Why would they have these holes unless they meant you to hook to them. If I can do this it saves me a ton of work and money (for fog light valence etc which I don't have and don't really care if I have it except about the tow hooks issue). I could tow hooks in in ten minutes.
Discovered these holes when chasing the rad leak which you see dripping off the crossmember.
