Is there a difference in a 4x4 3.0 and a 2x4 3.0
johnmillward
My daughters engine bit the big one a couple of days ago and I have been looking into either rebuilding or replacing the 3.0. I think I have come to the conclusion based on the thinness of my wallet that a recycled 3.0 is the way to go. The truck is a 4x4. I looked at my local auto recyclers and found that they have 3.0s from both 4x2 and 4x4 but that the 4x2 3.0s are just over $500 and the 4x4 is around $900. Is there a difference between the two motors other than maybe the oil pan?
Other than the oil pan and oil pickup in the pan, no there would be no difference, in 4x2 or 4x4 setup
Could be mileage difference or Flex Fuel(which doesn't matter, if you swap injectors with yours)
Also the year, Ranger '91-'94 had distributors, '95 and up were Coil Pack DIS
There were other changes every few years, good read here:
http://www.therangerstation.com/tech_library/3_0performance.shtml
Because of sensor placement and type the best swap method is to just use the long block(heads/block) from the "new" engine, bolt all the other parts from your 3.0l to that.
So the year of the "new" engine won't matter, even if it has a distributor or CPS, they are the same mechanically so can be swapped for whichever you need
Would I be better off getting a much newer engine say from a 2004 of so because of the mileage and then just using the long block? would all of my sensors and distributor bolt right up to that?
Yes, I don't see any problem with using a newer long block.
In '99 I think they did a redesign and changed to longer head bolts, so keep track of the model year of the engine, because if you get parts for a '94 3.0l it might not be the same for an '04.
Just as a heads up I think the '03-'06 3.0ls had valve seat issues, TSB here:
http://ww2.justanswer.com/uploads/s420/2010-10-11_155436_04_rANGER_tsb05-26-03.pdf/
On the 4.0l OHV's they redesigned the oil pan gasket 3 or 4 times, and they are not interchangable, not sure on the 3.0l, but easy to check part numbers.
Check parts numbers to see if intakes line up, they should.
I have not done a 10+ year swap but from what I see I don't think there would be a problem if you are just using the long block.
If you can get the VIN number of the vehicle the 3.0l comes from it can help in IDing the exact model, as they change versions mid year some times.
This thread has some good info for 3.0l up to 2003: http://www.therangerstation.com/tech_library/3_0-build.html
The FWD(front wheel drive) refers to vehicles like the Taurus/Sable not 4WD, these 3.0l engine were transverse mounted, but the block and heads are the same as RWD or 4WD Rangers, but because the coolant flowed out of the back of the engine to the rad the head gaskets were different to make the flow from front to back, head gaskets can be changed to Ranger gaskets and those 3.0ls can also be used.
Also price out Long Block exchange, rebuilt 3.0l long block price might not be that much more and you are not buying a "pig in a poke", used engines are tested and usually guarantied but........labor to remove and reinstall is not, lol.
could I use an engine out of a 2007 Taurus because they are only asking $325 for them.
Be careful when looking at a 3.0 from a Taurus/Sable. They used 2 different 3.0L v6s but only one will work in your daughters truck.
The Vulcan 3.0 is an OHV/pushrod engine with 2 valves per cylinder. It's basically the same as the engine in your daughters truck, and should work with only minor changes.
The Duratec 3.0 is a DOHC engine with 4 valves per cylinder and has nothing in common with your daughters engine. It would require lots of customization and money to work in a Ranger.
As for your original question, there shouldn't be any difference between a 3.0 from a 2wd or 4wd ranger.
Yes, they offered both 3.0l models between 2000-2007
LX and SE will have Vulcan, the one you want
SES and SEL offered Duratec as an option, so could be either
2008 both were dropped for the 3.5l Cyclone.
But keep in mind you DO have to change the head gaskets, no getting around that.
yes we have a Duratec in my wife's mazda tribute so I do know the difference between the motors. thanks for the heads up on the head gaskets. I will probably go with the Taurus engine since it is so much newer and most have lower miles than the 1994 that the recycler has on hand.
I have done 2 late model Taurus engines in my truck (2 = long story) but they work great just change the head gaskets to the RWD versions for the Rangers and swap your intake, exhaust & accessories. On my 2wd I am even using the Taurus oil pan as my original pan had an extra few holes in it. You can generally find the Taurus engines much cheaper, I think my last engine was a 2007, had <10K on it and I paid $300 ish for it, delivered to my door.
JP02XLT
