Is anyone other than me an automotive wiring nerd?
Is that a water resistant project box or something repourposed?
I just Googled waterproof electrical box and picked one I liked. It seems pretty good. Nice gasket seal and tight latches. When it arrived, the other day, I couldn't get the cover open. It had been outside in the cold and drew a vacuum inside. I sat it by the fireplace for a while until the air inside warmed up. I'll probably blob some silicon caulk around the strain reliefs just for good measure when it's installed on the truck.
For reference, here is a job I did 2 weeks ago at work. We replaced a machine. I had to unwire the old control box and wire in the new one. That included relocating the 2 big relays and a selector switch from old to new, which is a mod we do to these machines in-house to control a motor operated valve. No diagrams for the mod. It just has to be added and stuffed in the new box. Still not up to the standards I would prefer. But I only had 1 shift to get it done. The old box was a typical 20 year old rats nest.
@holyford86
When I decided to use an OHV 4.0l in a BII, I also decided to rebuild a complete new 4.0 harness. It is worth it just to have reasonable access to different areas of the engine bay, let alone to have increased reliability in a 30 year old platform.
Heat resistant conduit, +1 gauge multi strand OFC wire fully wrapped and routed fir access using a stand alone relay controlled light harness, powered strait from.thr battery.
Unfortunately, gasoline probably won't be available by the time my harnesses are rebuilt 🙅🙅🙅
I’ve been working on designing a zip tie sharpener… I don’t feel that your typical cutters leave them sharp enough. It’s also hard to get the correct angle when there’s barely enough space to squeeze your arm in between a harness and a solid object…. You know the space where those extra sharp zip tie dig into your forearms and basically trap you.
Have you considered painting curare on the ends? Then they get paralyzed in the act, and you can administer a good old-fashioned ass-whooping when you find 'em.
Or better yet just smear feces on the ends; then they go home and die from the infection.
Years ago I worked on a Jeep, that the owner had made a bracket under the radio with razor knife blades welded all over it. He told me that he had had one theft attempt since he made it, in which the would-be thief didn't get the radio, but he did leave a big bloody mess.
I currently have Deep Blue Sea fuse panels. They work fine but the footprint is huge and they force relays to live wherever they can cling to something solid. Kind of a spaghetti pile. One is battery constant and one is key power.
I used one of these for my efans that wasn't prewired to set it up so they would run with either the A/C or engine temp and really liked it. Not waterproof but compact and lots of capacity.
Amazon.com: RVBOATPAT 12 Volt Fuse Relay Box Pre-Wired Fuse and Relay Box with 4 Relays and 12 Way ATC/ATO Fuses Sealed 12V Relay Fuse Box Block for Auto Car Marine Boat : Automotive
So I am going to have one of the prewired ones and one I wire myself.
It seems you have the same issue I had, functional but large. That Amazon setup seems similar to the route I went. The setup I used has 5 relay places and 10 ATM fuse places. All of the relays have the negative control pin pre terminated to a common stud, and all the fuses terminated to a positive stud. I wired fuses 1-5 to relays 1-5 and used the other 5 fuse locations for things such as a common control circuit for all the relays, and circuit breakers for the trailer wiring. My only complaint with the Amazon setup is the lack of sealing on the terminals, but that could be a non issue depending on your usage case and mounting location, I've just been scarred by dealing with many rotten unsealed terminals on chrysler TIPMs, haha. Are those Mercedes fans?
For reference, here is a job I did 2 weeks ago at work. We replaced a machine. I had to unwire the old control box and wire in the new one. That included relocating the 2 big relays and a selector switch from old to new, which is a mod we do to these machines in-house to control a motor operated valve. No diagrams for the mod. It just has to be added and stuffed in the new box. Still not up to the standards I would prefer. But I only had 1 shift to get it done. The old box was a typical 20 year old rats nest.View attachment 122067
That's usually a good sign that it vacuum sealed, haha. I'd almost wonder if a liberal coating of dielectric grease before tightening the strain reliefs would be enough, as long as it isn't where water is driving at it.
That's a reasonable control station, I'm a little rusty on identifying industrial lego visually these days though, so I appreciate the brief description, haha.
@holyford86
That's above and beyond, but it should be nice. When I did my 4.0 swap, I pulled the loom, inspected the wires, and removed what I didn't need. The broncos I did, I did similar but visually inspected every inch of every wire and repaired/upgraded as necessary, then added all of the more modern things in then taped it back up after. For 50 year old wire, it was still flexible and solid, and much of it now controls relays instead of the full load of accessories, which all use relays and new wire, or in the case of the lights, far less amperage because they're all led now.
I feel compelled to chime in. I’ve done some simple projects, I’ve done some complex projects, I’ve done a bunch of weird projects, you name it, I could get it to work.
When I was young, my modus operandi was wiring or fixing whatever I had to do with what I could find on the side of the road or in the scrap yard. I knew all the basics so it was a matter of finding the right used stuff and making it work efficiently. Rather than run anything like a factory set up, I usually ran a couple of 2 or 3 inch loops at my turns and joints so there was plenty of spare wire to make modifications.
my first full vehicle rewire was my 56 Dodge telephone truck, a pick up with a service body. It was 6 V and it had a high and low headlights, marker lights, aftermarket turn signals rear marker lights, and brake lights, and a dome light. The wipers worked off vacuum. There were only three or four wires that ran to the engine, a flathead six with an oil bath carburetor.
everything was wired correctly, but it was wired with 1950s cotton coated wire. After the third or fourth time I lost something on the road, I got a bunch of lamp ZIP cord in 18 gauge and in 16 gauge and I rewired the whole truck in about an hour and a half. I had to get a few pieces of heavier wire for some things around the engine, those came cut out from the pull apart. Ran like a charm the rest of the time I had it.
later on my trailers, the Road Ranger, the missing link, etc. I ran all kinds of accessories after the basic lights. I never had a plan. I had a picture of the items I wanted to add in my head, but I mostly wired them one by one. That led to pretty good spaghetti, but I could always zip it together in a decent fashion. Most projects have inconsistent wires, but they’re all strong enough for the load. I used the cheap heat shrink cramps, and in critical locations, I will also slide heat shrink over them.
In more recent years, I have run many little strobe lights here and there or market lights. These have micro amperage. I have used transformer wire, I’ve used cat five using each pair as one line, and I’ve used fire signal wire from sprinkler systems. Aluminum speaker wire was a bust Boy, I really don’t recommend those last few to anybody on anything, but I had it in the shed of miracles and it all worked fine on the low-voltage.
Hence, the real reason I wanted to add to the post, is whatever the heck you guys do and no matter how hokey you do it, you could always point to me and say it’s a hell of a lot better than the way Rick does it!
My two cents, I hope it makes you laugh, and I hope veryit helps
That was kind of the kerfuffle with the efan control "module". The temp sensor on the engine grounded the relay to engage the fans. The A/C switch puts 12v to the compressor to engage it. So to get the efans to engage with both the engine temp sensor AND the dash switch for the A/C I had to kinda dance around playing with relays to keep everybody from going to war with each other if the engine got to temp and I had the A/C on.
That lil guy lives behind the DS headlight, it is tight.
The non sealed thing was a concern but really they are mounted high enough that if they get flooded there is a good chance the engine isn't going to make it. You can see them on the PS inner fender in the efan running pic. If a guy hydrolocks his engine and swamps is new interior who cares if the fuses got wet?
I do have the cover that hid all the nasty 2.8 solenoids/relays to add additional splash deflections.
They are more sealed than what I have and I haven't had an issue with them yet.
I don't know what the deal was with the TIPM's, in a previous life I sold a pile of those things lol. It got real fun as they decided to quit making/remanning the older ones...
And yes they are C230 Kompressor fans pulled by the infamous @PetroleumJunkie412 himself.
Just to let you guys know what I do. I turn this
Into this about 12 to 15 times a year haha
For these
Here’s the switch panel I built for my first SxS. I’m trying to find some pics of the fuse/relay block and wiring. I’ll post them when I find them.
Wiring.....temporary is alright for testing, but the final install should be as good as or better than OEM. Electrical failures are 90% why structures catch fire. This includes portable heaters. I love pilot lights on relays, however they can backfeed through the light (LED) and I'm scratching my head again!
I was so impressed as a kid how NASA - Houston (JSC) and other experts (contractors) troubleshot electrical issues (including intermittent sensors) from the ground in their lab where what was flying was laid out with the same exact equipment and their ability to simulate and recommend the action required. Logical explanations with drawings will always be a high level skill set & something that requires patience, intelligence, & experience. Nice to see that here!
I've spent a large amount of time learning what didn't work, and melted a ton of wires and components in the process, haha. You're making it work, and if it works, there's something to be said for that, that's what revisions are for, to make it better.
@85_Ranger4x4 that seems like an elegant way to make that fan issue work. Is that a program you're using to generate diagrams? If it is, what is it? I've got very many hand drawn diagrams but it would be nice to have them stored electronically.
@Robertmangrum.rm what're you building for a platform? Prevost?
@MaicoDoug that's what I try to do, I've been working on shuttle buses built on Ford chassis for the entirety of my career, the way they tie into the oem stuff is always poorly routed and half ass terminated, it usually always fails at these points. At one time we had 3 of them built at the same time with consecutive vin numbers on the chassis, all of them were wired completely differently, even though they likely went down the line one after the other. I've learned a lot about how not to do things from fixing these. And don't even get me started on bluebird school buses, haha.
Yes sir. Prevost is our main platform. We have done some MCIs and Eagles. But Prevost is the top of the line when it comes to bus chassis
I do not enjoy doing electrical work. I can get the job done and usually don't have any problems but I don't enjoy it. I don't hate it either. It's just there, staring at me with hate and spite.
@Robertmangrum.rm Prevost had a final assembly line in my town for a few years, structures came down from Canada and were assembled here. I've been in and around them a handful of times and it's a whole different level compared to the platforms I'm familiar with.
@sgtsandman Sounds like me with brakes and 4.6/5.4/6.8 exhaust manifolds, haha
By any chance, is your mother-in-law’s name “Electrical Work?”
