The switch is inside the door. It works internally off parts of the door latch mechanism. You have to get inside the door, towards the back of it, just under the latch. If you replace it, it is just a quarter turn and undo a wire connector to get it out.
If you want to lube it, spray /soak the latching mechanism from the outside. WD40 doesn't conduct electricity.
