- Sep 9, 2007
- Age
- 86
- East Texas
- Automatic
The most common way is to mill the cylinder head, taking metal off the block side. This, in effect, reduces combustion chamber size raising the ratio.But for things like the cam and whatnot, how do I get there? And how do I obtain the Cc(combustion chamber?) of the engine? From the tech page, I can get bore and stroke, but that seems about it.
If you are seriously considering this, call the tech line at the following site. They can tell you how much milling it takes to raise the compression ratio to the level you want.
www.esslingeracing.com
Unless you can find the volume of the heads printed somewhere, you can measure them yourself. Clamp a piece of plexiglass/thick plastic over the combustion chamber in the head. Drill a hole in the plastic. Using a graduated beaker, or syringe, fill the combustion chamber with mineral oil, and measure how much you put in. There is also a formula somewhere that will get you close. I'll see if I still have it somewhere.
