- Feb 1, 2022
- midwest
- Total Lift
- 3" BODY LIFT
- Tire Size
- 33"
I have a 1984 Ranger 4wd (must be 4wd to be compatible) and my front cab mounts are gone. No luck finding them online or a parts truck in my area so I've resorted to having some pieces cut on waterjet and fabricated. If anybody could provide measurements from center of mounting hole to the frame wall (horizontal measurement) then top of frame to top of mounting surface (vertical measurement) that'd be perfect. It is the frame-mounted bracket under floor pan where your feet would be if you were sitting in the truck; mated to frame by 4 rivets. Thanks for reading.
