88ranger2.95sp
- Oct 21, 2007
- Age
- 35
Ok over the weekend I've pulled the 2.9 out of Ranger #2 and looked it over, replacing the rear seal, pan gasket, clutch, slave cylinder, clutch line, oil pump and oil pickup tube. Whew it's been a long few days.
Now the truck isn't on the road, but I have driven it around 100 ft. When I hit first to second gear, it shifts fine. A-OK.
The clutch pedal doesn't come up as high as it used to. Is this normal? I think it's ok cause the clutch is new and it engages lower because it's engaging sooner. I think...
Also now it's a little harder to get into first gear from reverse. YOu have to almost go into second and push it harder. Not real hard, but more than i would like. It's been bled. SHould I bleed it more?
What's the correct way to bleed it? The instructions said to pump 15 times and open the valve let the air escape, then close it. Seems simple enough, and I've bled brakes before. This is what I did. If there's a better way, lemme know.
If anyone can answer these simple questions that'd be great. I appreciate all the help.
Rob
Rob
