tenga
Alright, to start off I've been having issues for a month now. The truck will start up well every time, but usually after several minutes of driving there will be a loss of power, seeming and literally sounding like someone threw a choke on. If I pop it into neutral the engine will stall and sputter until it dies. I pulled codes and got a code 13 (idle out of range) and code 41 (running lean).
Checked for vacuum leaks and couldn't find any, so I continued to look for exhaust leaks and ended up seeing some carbon buildup on the connection between the driver side header and the exhaust pipe.
Im posting to either confirm my suspicion, it get other ideas from people with similar problems.
