Brain75
- Aug 8, 2024
- ~Sterling, Colorado
- 2.9 V6
- Manual
- Tire Size
- 215/70R14
thought for you on the running like crap and stalling when you come to a stop - the IAC valve can cause that - test by removing and see if it makes it worse... same means it is not working right. bench testing it can be done too
snipet out of an article:
If the idle air control valve is hot (50°C to 100°C), you expect a resistance value between 21.5 Ohms to 29.5 Ohms.
A cold IAC (-13°C to 50°C) is expected to have a resistance between 17 Ohms and 25 Ohms. In some car models, the resistance value goes as low as 7 Ohms.
electrouniversity.com
How To Test Idle Air Control Valve With Multimeter (GUIDE)
If you're having problems with your idle air control valve, don't worry. We created guide about how to test idle air control valve with multimeter.
