Do I have this right, you are looking to put a manual (stick) behind a 5.0 so you quit burning up E40D?
Doesn't a T5 bolt up behind a 5.0 straight....? you would need the S10 tailhousing to keep the shifter in a reasonable location instead of in the back seat, but they can be had in the junkyard. Someone verify me in saying that though.. I though the mustang came with a 5.0 and T5 combo for some time.
T5 can be bolted to a 5.0, but as noted you need the S10 tail housing and you will need to setup some method of activating the clutch (the M5OD slave cylinder doesn't "bolt in" on a T5).
But the M5ODR-2, found in F-150 behind the 4.2 and 5.0 engines. does bolt in* and has the same hydraulic clutch slave as the M5ODR-1 (the one found in Rangers).
*Caveat: The M5ODR-1 found behind the 4.2 uses M12 bolts which are close enough to the 1/2" bolts for the 5.0 to be able to cross thread. And 1/2" bolts won't fit in the M12 holes (but a quick reaming with a 17/32" bit solves the issue).
p.s. A T-5 is really a pretty light duty transmission; if OP is burning up E4ODs, T5 probably isn't best choice. M5ODR-2 is considerable heavier (but still not real rugged).
I highly doubt you will have a hard time finding a M50DR-2, and even less likely to find (what was a unicorn for me) a World Class T5, but if you happen to, a WC T5 is the ticket... except no WC has the Chevy S10 tail housing, and from what I understand swapping tail housings is as much work as rebuilding the trans.
View the Modern Driveline blog for helpful articles, videos, and DIY resources. We are your trusted source for everything manual transmission conversion.
www.moderndriveline.com
I also understand that almost all the WC ones were in mustangs.
For
