OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
The relays that are under the NAPA Proformer line are garbage. I got a '92 car, about two years ago fuel pump died, we replaced the grey relay($10) along with other stuff.
So now every now and then I would go to my car and my battery would be very low or drained dead, did this once every six months, I've hit three deer with this car and was worried I had a drain somewhere, shorted wire, BUT I COULD NEVER FIND IT!
Now last Thrusday my battery was damn low, I had to leave for work so I jumped it. I decided I would disconnect it while parked at work and see if my battery would drain down(shorted battery?) after work it still had a charge.
Now as I hooked it up after work, getting ready to go home, and heard a HISSS HISS HISSSSSSS sound from my fuel pressure regulator, I'm like WTF is this? So I went to the back of the car and my fuel pump was running!
I had no keys in the ignition, so I thought either my made in china relay was sticking or my oil pressure switch was sticking.
Relay was easier to get, So I get a duralast relay(($17)at AutoZone and vola!
I shook the grey NAPA relay, and the dang thing rattled! Opened it up and a loose wad of solder was loose in there,shorting out the relay.
I can't get my 10 bucks back because I lost my receipt, and it is electronic.
