- Nov 27, 2008
- central IL
- State - Country
- IL - USA
- Drive
- 2WD
- Automatic
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
I have a 94 that is running poorly.I sprayed wd-40 around the engine and have replaced all the vacuum lines,not the plastic ones. It has a new o2 sensor. I have cleaned the mas and the idle control valve.air filter is clean,air filter box is cracked. newer spark plugs and wires,oil fresh. I was wondering where to start? It is not throwing any codes? I was wondering if maybe the timing or the crank sensor. I did not use the spacer tool to set the crank sensor. I am not sure what check to without codes. I was thinking about checking fuel pressure and a compression test. Thanks for some help.
