identifying a 700r4 I know its a ford site lol
2.3
The serial number is 6fam y 01164907 11 it has a 10 vane pump according to the 732 on the end of the pump casting number an has a 30 spline input shaft i need to know the year so i can order a rebuild kit. Also from info I've read it says 87 and later were the only ones with the 10 vane pump and 30 spline shaft. So did Gm actually start in some 86 transmissions? Its also a 4x4 transmission
Aside from having one for a small v6 with the smaller input you don't need to know all that much to order rebuild stuff. Lose the 10 vane rotor and order a new style 13 vane rotor and slide. The old style rings are brittle and break. Anything after mid 84 will be 30 spline input for the v8s. Does yours have the aux valve body? Your pump is for an 88 and up. With that info you should be able to get what you need. When getting parts at least get an upgraded shell if not the beast shell. Also get an array of 3-4 steels so you can restack that clutch you should be able to 7 in there.
