i wanna go fast
Ranger#1
lake havasu
allrght i wanna know how fast you have driven in your ranger list gears engine size tiresize ......
me iv had my 4.0 3.55 235/75r15 goin probly around 105 idk the speedo was at the overdrive spot:thefinger: now i dont wanna here speed is bad and your retarded for goin that fast i kno all thiss is true but i just wanna kno who else pushes it like me :thefinger:
the brick-like aerodynamics paired with the ttb front suspension makes even 85 feel too fast. ill keep it at 70 thanks
thats not even the speed limit roadtrips must suck
well, i had my 88 2.9L 3.73 with 275/50r15 2wd 5speed with the speedo pegged. i never had it recalibrated for the tire size but i estimate 110mph...numerous times, but the 99 3.0L 237/75r15 auto 4.10 gears 4x4 has only been to 98mph, i dont want to hit 100 and have the computer shutoff
interstates in ohio are 65 mph limit, so i keep with traffic anyways. road trips get done in the EGT though. the feel of my car @ 80 mph vs my truck @ 80 mph is huge.
yea here its 75 mph and yea i would rather a car than a truck lol
Someone legally distinct from me got his Bronco II with a 4.0, 4.10s and 33s to 100MPH :fie:
I was right around 100 a couple weeks ago which is real unusal for me. Normally I drive 50-70 max. 2000 ext cab 3.0 auto 4:10's and 31x10.50x15's
Once while I was trying to pass a semi I just put my foot down until the computer made the throttle cut out, 95mph. 4.10 gears. Stock tires on 16 inch rims not sure of the size, if I gave a tire size I'd be guessing. 245/75/16?
isnt the 01-and up limited to 90mph?? if so...
2003 fx4 l2 4.10 31x10.5x15 120mph it gets a little scary
im gonna call it BS, my mom's 03 2.3 has the limiter.
my 99 2.5 5spd, 225/70/R15 with 3.73gears, has reached the 100mph mark, i think its limited there, cuz when trying to pass it the engine tries, but then the needle goes back to 100mph
isnt the 01-and up limited to 90mph?? if so... im gonna call it BS, my mom's 03 2.3 has the limiter.
not need to call bs, if you buy a aftermarket tuner, you can change the rev limiting rpm or even remove it completely.
well, true, but he didnt told us that, he would post, 120 with modded ecu
