ncsdaonex
- Dec 5, 2008
i was driving my truck tonight and i was in 5th gear and when i went to go in 4th i hit reverse and now it wont go in 5th gear no matter how hard i push and if i put it in reverse when i let the clutch out it pops out of reverse. even if i hold it in and let the clutch out it grinds no matter how hard i hold it in reverse. 3rd gear makes a slight grind when i go from 2nd to 3rd and 4th is tighter going in than normal. normally when tranny is in neutral you can move gear shifter back and forth and you still can but when you push it to the right in neutral and get lined up between 5th and reverse it will stay there when you let go and it should pop back in between 3rd and 4th. Any tranny experts out there tell me what i screwed up and how to fix it and a rough price range. Thank you!!!
