- Aug 6, 2008
- Age
- 36
- Pleansant Hill, IL
- Automatic
if none of this stuff works... just replace the motor. some 2.9s dont last that long. she may have blown something internally.
I just happen to be reading on another site and stumbled on this, "Everytime you rev that engine past 5,500 RPM's you remove a slight bit of tempre from the valve springs. You MAY be able to rev at 6,200 (factory rev limiter is 5,800 max), but you won't be able to for long. You will not notice it, either, it will creep up on you and one day you will be struggling to pass a car on the freeway.
The factory valvesprings are weak and it takes some cash to get them up to par. The factory valves won't put up with it for long either."
Seems extremely likely here! As a matter of fact, I'm wondering if I might have a slight bit of valve spring issue.
He could very well check for a valve leak......
Put a peice of paper, or dollar bill up to the tailpipe. If it is steadily blown from the pipe, things are most likely fine. If it's sucked towards the pipe at times, a sticky or worn valve may be suspected.
As for loss of compression, a blown head gasket, cracked head, or bent valve can be possible. IIRC, Wicked Sludge had one of the vavles bend on him on his #4 cylinder.
Your post sounds like a valve spring commercial.. I'm betting springs that are OEM can withstand factory maximum rpm for as long as aftermarket ones..
