Dwright4
- Jun 29, 2008
- Automatic
I have a 99 Ranger with the 3.0 Flex fuel in it. The truck has 170,000 on it and has ran great until a few months ago when it started running rough.
The truck has a hard time starting and when it finally does it has a hard time staying started unless I place my foot on the gas. The truck has no power at all and when you finally do get to 65mph on the highway the thing will not stay in overdrive more than 5 or so seconds then shifts back to drive..when in overdrive the truck is stumbling like crazy and shaking the whole truck..
So no power on Highway,hard Starting and will not idle..Here is what I have replaced in the last 2 months.. Battery,Battery Cables, MAF, Plugs,Wires set,Ignition Coil Pack,DPFE,Gutted the Cat(thinking it was plugged),All 3 O2's, All Injectors,Cleaned the IAC, New upper and lower Intake Gaskets,Cleaned the EGR,New Fuel Filter. No Codes at all
BTW if I turn my A/C on it will kill the truck when in park or neutral even if driving down the highway.Any ideas would be nice
Thanks
Thanks
