That is a good reason why you are having trouble. Pull all the bolts and push the trans back enough to get the old plate out. Slide the new plate in and get a full set of bolts to put back in. On yours the two bolts that go through the hollow dowels are about 1/2" longer than the upper 4. They're m10-1.50 bolts.
Once you have ALL the bolts snug then you can start to tighten them. If you put a bolt in and tighten it then move to the next one you will end up with missing bolts as well.
