- Nov 28, 2010
- SE Idaho
- 4.0 V6
- Automatic
My speedometer stopped working about 3 months ago; a minimal amount of investigation showed that the teeth had worn off of the speedometer drive gear inside my BW1350 TCase. The driven gear didn't look too shiny, either.
I pulled the rear driveshaft, bought a 30mm socket, pulled the mounting plate off the rear output shaft, popped the oil seal out, and confirmed that, yes, my speedo drive gear was toast, and that I had a red (6 tooth) gear, which is too slow for my stock-sized tires anyways. So I put it all back together and started looking for parts.
There's a great transmission supply warehouse here in town, and they were able to order in a "good used" 7-tooth gear for me. These gears, either the 6- or 7-tooth, are apparently rare and valuable anymore. So today I went and picked up the gear (which is in beautiful shape), and a 17-tooth driven gear as well, and this evening I attacked the problem.
All proceeded well, until I went to put the 30mm nut back on the rear output shaft, to hold the driveshaft mounting plate on. The factory service manual said it needed 150-180 ft-lbs of torque, so I grabbed hold of my 15" breaker bar and torqued it down a good grunt-and-a-half. There was a funny "ping" sound, and the nut got really easy to turn for a moment...then it came right off. I had broken the threaded end off of the rear output shaft.
Now, I'm not a huge guy...6'4", 210 lbs, an active cyclist, and I might be able to do one chin-up on the bar. Lying on my back under the truck, there's no way I put more than 200 ft-lbs of torque on that nut, right? To get it off the first time, I had to grab the frame rail and push against the end of the breaker bar with my foot. D'ya think that sometime in the past, somebody overtightened it with an impact wrench, and weakened the threaded shaft?
I intended to rebuild my transfer case soon, but I was hoping to wait a month or two, and arrange to have a full day off to work on it. Now I'm stuck. I'm relying on my carrier bearing to hold the driveshaft mounting plate onto the splines of the rear output shaft, so I don't dare drive very far or very hard. I might be able to get a "good used" rear output shaft at the transmission warehouse (the parts guy mentioned a "box full of misc 1350 parts" lying around), but I'm not sure my budget will support this latest disaster.
Also, what are the chances I can rebuild my transfer case (or at least replace the rear output shaft), using the '88 ford factory service manual, in 4 hours or less, so I can get to work on Friday? Or should I plan to ride my bicycle to work? It's only 12 or 13 miles, but an hour on the bike riding home, is an hour I can't work on fixing this problem.
Comments or suggestions are greatly appreciated,
Spott
Spott
