Hydraulic clutch problem
Marine0317
So I have a 1989 bronco ii Xl v8 302 swap , I was coming down the road my clutch petal got hard as a rock I forced it to the floor it in return popped the hydraulic clutch line out of the transmission . I have tried to put it back into the hole , it's goes in but don't lock in or seat in right . I have looked for a retainer clip or something to help me but cannot seem to find help . Can someone please give me some advice thank you in advanced
Here are a couple of videos of clutch hydraulic line connections
http://www.youtube.com/watch?v=RVjEMoroZQM
About 2 1/2 minutes into this one
http://www.youtube.com/watch?v=91IYY_YENRw
But it does read like your slave has been frozen, after you get the fitting connected have someone push down on the clutch pedal while you open the bleeder, see if you get flow, then after air is out try pedal without releasing pressure(bleeder) if pedal is not going down then slave will need to be replaced :(
