hybrid lift questions
v6Ranger
Has anybody got the skyjacker kit and used jeep coils with it? Also with the skyjacker kit do you still need to do the f series shock mount or similar setup or are kit shocks long enough?
You can fit the Jeep coils with the SJ kit, sure (the only kits I know of you cant is James Duff with the early-version replacement coil buckets). The stock buckets do need to be modded slightly to support the coils correctly so they don't bow outward though.
As for shocks, you can use normal length shocks, however to gain the full potential of the coils, I really would suggest extending the mounts for longer ones.
