- Jan 29, 2009
- 1998 and a few
- Automatic
My 92 manual says for the shift on the fly for 4 hi at the maximum speed to be 88 kilometers per hour.
For 4 lo it wants the tranny in neutral at a dead stop. ive never had to use 4 lo.
And never use the 4x4 on clean dry pavement. Keep it in 4x2 Its hard on tires and hard on the tranny.
while the truck has a front differential and a rear differential which compensates for speed differences between the wheel pairs. As in, when you go around a corner the outside wheel is going to spin faster then the inside wheel.
The vehicle doesn't have a differential between the front and rear drive shafts So it cannot compensate between different wheel speeds from front to rear. And yes they will turn at diff speeds depending on the turn rate of a corner.
Dirt and Snow and Mud will absorb the speed differences while pavement will not.
What the hell gears do you have? Cause i was a 4000 rmp with 3.73 gears and a 2.9
