Fairlaniac
- Dec 8, 2007
- Age
- 65
- Denver, PA
- 3.0 V6
I'm rebuilding and replacing wear items on my '91 Ranger. Just about have the LH beam & radius arm out. RH side removed. I pulled the shaft from the hub to slip joint on the RH side. The ujoint and shaft still off the RH side of the differential will come off but my day is done sp I'll proceed tomorrow. How does the ujoint & shaft come out of the RH side? See picture, does this clip need removed? Can I get to it easily? I've got to pull it because the u-joint is frozen solid, no movement at all.
Thanks,
Thanks,
