harriw
Hey folks,
Just got a '94 ext. cab 4x4 w/ 4.0L from my brother-in-law (http://www.therangerstation.com/forums/showthread.php?t=36137), and have a question. In my experience, stick-shift vehilcles have solid E-brakes (i.e. you stall out before you can get the vehicle to move an inch with the e-brake properly applied). On the other hand, it's usually pretty easy to drive along with the e-brake on in automatic-equiped vehicles (I guess because there's no "park" with a manual...?)
So on to my question... The e-brake on my new Ranger doesn't seem to hold very tight - I can definitely drive with it on.
Guess I should explain - I brought it home and pulled in the driveway yesterday, went to apply the e-brake, and found that it was already down a click or two (rear wheels stank, so it was definitely making contact). Not sure how it happened, but my guess is I did it while stepping on the clutch at some point. Don't know though - I've been watching my left foot, and I'm not convinced... I pull the break release every once in a while when driving now too to make sure it's off, but it hasn't happened since.
I'm still getting used to this new e-brake arrangement (I'm used to handle-style e-brakes), and forgot to take it off while backing away from the gas pump this afternoon, and was quite surprised at how easly I could drive away with the e-brake on (I realized almost instantly that I forgot to take it off, so I only went about 4 feet with it on).
So, is this normal (maybe that 4.0 is just THAT strong?), or should I have a look at my e-brake cable and/or rear brakes? My brother had his mechanics go over this thing with a fine-toothed comb, and they did actually put new front brakes and rotors on for me. They could have missed it I suppose - or could a loosely-applied e-brake toast the shoes and drums that badly? It was about 20 miles on the expressway from the dealership back to my in-laws house where I noticed, but it could have been applied anywhere between those two points.
I'm also not really stomping on the e-brake when I put it on. I could probably get 2-3 more clicks if I really wanted to. Think that would make any difference? I'm not worried about the truck rolling away in a flat parking lot - I just want to make sure my rear brakes are working and that my back end won't swing out next time I have to stamp on the brakes for a squirrel or something.
Thanks a lot for any help you folks might have!
-Bill
Any thoughts?
-Bill
Any thoughts?
