- Oct 14, 2010
- Williamsport, Pa
- Automatic
You have to keep in mind that there are certain weaknesses to the D35. For example, the u-joint caps have a tendency to work their way out of the shafts, thus shattering them. Another fault is the weak hubs.
Tack weld the caps on and get Warn 37780 hubs and you shouldnt have many problems with that front end.
Keep your inner/outer nuts tightened as well. They can work loose w/ larger mud tires.
