Fairlaniac
- Dec 8, 2007
- Age
- 65
- Denver, PA
- 3.0 V6
- Manual
A while ago I had this post http://www.therangerstation.com/forums/showthread.php?t=140556
It took a while but I decided to change the seal today. To back up a bit I purchased the trans in the picture here.
I decided to use this trans to see how the seal comes out and replace it. I did this back in the winter so I knew what I was up against.
So you see the inside of the extension housing for 4x4. Today I take the transfer case out of the Ranger to find this.
Both have a FM-146 tag on the driver side of the trans. I'm baffled seeing what I see. Are there multiple models of the trans and extension housing?
So my issue was oil leaking out between the trans and transfer case. I assume oil is passing through the bearing shown behind the hex nut in the second picture? I guess this is no easy, in the truck fix?
I guess my "beater" truck is now my "POS" truck?
Thanks,
Thanks,
