Gary DuBois
- Jan 30, 2017
- Age
- 34
- Puyallup Washington
- 4.0 V6
- Automatic
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 31 inch
I would like to talk to other owners
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Your ranger is of interest to me =) i have never owned a 3.0 v6 but i heard they are good engines. Please tell me when you bought your ranger and everything about your ranger do you have pictures on your truck.I own a 2002 Ranger XLT 4WD, 3.0L if that is of interest. PM me anytime.
What did the Missouri motor vehicle department use that ranger for ? How much did you and your olde brother buy that ranger for ? My condolences about your dad passing away. 149,000 is still low miles for a ranger even with the 3.0 v6. Thats good that you have had no real problems. When did you replace the tires, shock absorbers, battery, starter, spark plugs, plug wires, head lights, and one fuel injector and how much did all of those individual parts cost for you.This 2002 Ranger was owned by the Missouri Motor Vehicle Department until November of 2004 when offered for sale with 43K miles on the odometer. My older brother and I bought this truck for our Dad who drove it until he died in 2015. My brothers then offered the truck to me with 111K miles on the odometer.
I now have some 149K miles on the truck. I have had no real problems so far with the truck, just the usual - tires, shock absorbers, battery, starter, spark plugs, plug wires, head lights, and one fuel injector.
I did wisely do the Mustang rear disk brake conversion as documented on this website.
The drivers seat was slowly collapsing when I got the truck so I had a great auto upholstery shop redo the interior - seats, head liner, and sun visors. All well worth it.
Also, over time, have had both front fenders replaced. The left was clipped in the Home Depot parking lot - another Colorado hit and run. Then I discovered a previously patched rust hole in the right front fender which was replaced rather than patch again.
The 3.0L has been fine save for being a slow dog. Oh it will run 80 mph all day on the interstate. Just takes a time to get up to speed. This engine also had no end of leaks which I finally paid to have fixed - valve cover gaskets, oil pan gasket, and engine front timing chain cover.
The latest issue is an ignition lock cylinder failure as posted on this website.
Compared to what? $50K for a new Ranger, I consider every buck invested in this 2002 Ranger to be a true bargin.
I found those 2 different articles interesting =) My dad forwarded me the second article ford ranger fx4 off road and level ii by the years in late part of 2022 after i bought my 02 ranger fx4 off road with my own money i made from working im 32 years old with mild autism and i bought my 02 ranger fx4 off road for $10,500 four hundred dollars less than what the seller was asking so i got a good price =)You may find this interesting:
The Ford FX4 and Wheeling With Ford - The Ranger Station
On September 7 2001, The Ranger Station and its members got the opportunity to get a first hand look at the Ford Ranger FX4 that was slated to be introduced later in the fall. Although you’ll find other Ranger sites … Continuedwww.therangerstation.com
Ford Ranger FX4 Off-Road and Level II - By The Years - The Ranger Station
The Ford Ranger FX4 was introduced in 2002. Here is a year-by-year description of the FX4's offered from 2002 to 2009.www.therangerstation.com
Oh, nice. I need rear discs in my life! Not only are the drums old tech and a pain to replace springs/shoes, I always thought they were woefully underpowered for a loaded ranger. This is awesome, I need to look into this.This 2002 Ranger was owned by the Missouri Motor Vehicle Department until November of 2004 when offered for sale with 43K miles on the odometer. My older brother and I bought this truck for our Dad who drove it until he died in 2015. My brothers then offered the truck to me with 111K miles on the odometer.
I used to want to install disc brake in the rear because of the difficulty of doing a brake job with brake shoes. However, I upgraded my rear brake shoes at around 50K miles to get better braking. I had planned install disc brakes when those needed to be replaced again. I now have 283K miles on my Ranger and have never had to do another brake job on the rear and the shoes still have many miles left on them. So, the problem of having to do another rear shoe brakes never became a problem.
I tow a lot too and after upgrading both the front and rear brake materials, I have not felt I needed better brakes. I can't say that for the OEM brake pads and shoes though. The 02 Rangers had smaller front discs than the later model years and were very marginally safe. I had a couple times when they faded on me and nearly caused an accident. It happened both with and without towing. It is amazing how much improvement you can get with high quality brake pads and shoes. It is also much less expensive than upgrading rotors, calipers, etc.
How heavy do you tow with it? I have a bass boat that weighs 3500-3800 lbs and I thought about pulling it with my Ranger once just to see how it does.I used to want to install disc brake in the rear because of the difficulty of doing a brake job with brake shoes. However, I upgraded my rear brake shoes at around 50K miles to get better braking. I had planned install disc brakes when those needed to be replaced again. I now have 283K miles on my Ranger and have never had to do another brake job on the rear and the shoes still have many miles left on them. So, the problem of having to do another rear shoe brakes never became a problem.
