How many CFM's to easily cool the engine?
First off it's a 1992 2wd
Right now it has a single 700 CFM pusher but still gets warm at idle. I'd like to either mount a puller or upgrade but I'm still using the stock alternator as well.
Is there a preferred electric fan swap?
Taurus fans are well liked by many, seem to fit well, and are readily available.
+2 on the Taurus fan, I have had one on my truck for years, I have a Delta current controller and have had zero issues
JP02XLT
Yes, you need to create some airflow over the condensor when the AC is on, I run my fan on the low speed with the AC on and its ice cold and have never had an issue with it that way.
JP02XLT
E-fan needs a Relay to work, temperature activated, a manual switch is just asking for trouble.
If you do alot of 4 wheeling and water crossings you can add an off switch for e-fan to keep engine bay drier, and you put a BIG RED light on that switch so you know when it is off, lol.
If you have AC then you add e-fan relay activation to AC clutch activation, how you do that is based on your e-fan relay setup and AC activation circuits
Temp & AC needs are all controlled by this controller, I have tried other controllers this one is by far the best I have seen. I have also done the seperate relay setup for temp & AC, this blows all other methods out of the water, if you want something trouble free.
http://www.dccontrol.com/relay_controllers.htm
All done automatically for you
JP02XLT
Factory mechanical fans will move a few thousand cfm, I try to keep that in perspective when selecting fans. Taurus fans work great or dorman 620118
Sent from my SM-G920R4 using Tapatalk
What engine do you have? Why go away from the mechanical fan?
Thanks for link!
Your welcome, it may take a month to get one if he does not have any built but they work great and he has very good customer service for any questions
JP02XLT
