- Aug 6, 2007
- Age
- 40
- Westport, WA
arguing that advancing cam timing doesnt help to increase power is like arguing that a P&P doesnt increase power. anyone whos in the business knows it to be a fact and they wouldnt make adjustable cam sprockets it DIDNT accomplish anything...so im not going to argue the point with you anymore.
whats easy about changing cam timing? surely has nothing to do with the fact that it takes 1/2 an hour and only requires basic hand tools..
i realize his cam timing wasnt set with an aftermarket kit..i was making the point that changing the cam timing from stock will not damage the motor....before this got so far off topic.
do not back pedal your jake brake argument...as you said before: you thought the valve was help open "during all cycles of crank revs", allowing the internal drag of the motor (which isnt much) to slow the truck. in reality, the exhaust valve is opened at TDC of the compression stroke. this works because it prevents the compressed air from pushing the piston back down in its bore thus recouping much of the energy wasted from compressing said air. this would be what you could call a "worst case" scenario of cam "timing"...opening the valve against the cylinders full compression (which is many times that of a gas motor, as you said), which does not hurt the cam, pushrods, rockers, valves, seats, or any other part of the motor.
i wasnt saying my escort motor was anything like the 2.3 in the OP's truck. i was simply giving a real life, first hand example of a motor that ran very mis-timed for quite a lot of miles and is no worse for the wear. have you run into an engine that was damaged from cam mis-timing first hand?
BTW, I think Sludge is winning the argument...
