How Can You Tell If It's Your Reservoir or Power Steering Lines?
HilaryP
Northeast Pennsylvania
Car parts places don't sell replacement reservoirs for '94 B-3000s. Can't for the life of me figure out why:D . I can't tell if the leak is coming from the reservoir, and I don't want to pay to have the lines--which definitely could use replacing, even if the fluid wasn't leaking--replaced, only to have it turn out to be the reservoir. Is there any self-test you can do?
Thanks.
Does Mr. Oaks' site have replacement reservoirs for this year? I would appreciate an answer before noon, because the place I have an appointment refuses to install or use parts they do not order, and I will cancel if necessary. Thanks again.
Clean off the hoses, from the steering box up to the pump, start the engine and watch for where the fluid is coming from.You most likely have a bad seal on the pump if the leak is up high, or, if the leak is low, one of the seals for the box itself could be going out.
