Wanted Horn Module for '88 Ranger W/O tilt wheel
rosscob
Oregon Coast
I'm looking to the horn module with wires and the two brushes that mounts to the underside of the steering column behind the steering wheel on my '88 Ranger without tilt wheel.
I can check this evening. I think its still on the column I have.
Looks like I still have one, not sure what it's worth? $40 shipped?
Sounds good to me as long as the brushes are still in good shape and it comes with the wiring and plug. Do you have a PayPal account? Does that truck still have the factory cigarette lighter?
I'll get it pulled tonight and it will include wiring and plug. Ill see if i can find the cig lighter, I doubt its there since this truck was already gutted when I drug it home.
Well...not great news. One brush is spring loaded and looks as it should. The other looks fine, but doesn't really move in or out
Is it just stuck, can you pull on it to get it to move?
I dont want to break it, I tried pulling, pushing, and wiggling and it just kind of wobbles around in place. It was touching the ring on the steering wheel before I pulled it. Ill try to get it free again this evening.
Thanks! Maybe soak it down with some WD40 and let it sit upright for a while. I don't think it will hurt it.
What would you take for it in the condition it's in? I can use it as a pattern to make a new one. I've got some HDPE I could use that would work great. Thanks!
