homemade pivot brackets
offroad junky
would someone be nice and measur there 4-6'' drop pivot brackets(both sides)b/c 165$ is to much for new ones. also the drop torsionbars would would be great thanks in avance!
btw if someone has already done this any info would be great thanks:headbang:
My suggestion would be to look for some used ones (or a used lift). Those brackets are not exactly easy to copy and have it be sturdy (you could probably extend the stock ones 3-4", although you WILL need to reinforce them to handle the added leverage on them).
thanks for the info. iwas only planning on 4", the reason i ask is b/c the truck is on its last leg. but is still my trail rig till the next one is done.(i got bigger tires so need to go bigger)
i'm not trying to "make" new ones just exstend the orginals. another ? does the kit drop the tranny mount? thanks
The only kits that do anything to the tranny mount are the ones that have extended radius arms. It replaces the crossmember but keeps the tranny in its original location.
