Holley terminator EFI
Edgefevah
Calgary Alberta
Has anyone here had the thought of installing this kit on a v-8 swapped ranger. it's $2,000, but sure would be awesome.
were you wanting the terminator TBI kit?
what is the biggest selling-point for you?
the fact that it self-tunes?
the fact that it is efi that drops in place of a carburetor?
the fact that it supports quite a bit of horsepower?
the fact that it is universal, you are intimidated by the prospect of using a junkyard harness, and therefore seems like it will be a fairly painless wiring install?
once we know your reasoning behind wanting it, maybe we can steer you a better route.
having used one, i would use a stock efi manifold, with the Holley HP ecm if I did it again, but most guys just use an ecm/harness from a junkyard, and have it re-flashed. if your engine is pretty stock, and you aren't looking super fine-tuneability I would go that route.
check here: http://forums.holley.com/forumdisplay.php?13-Holley-EFI&
