jhammel85
Guest
I've got a strange problem with my 87 Ranger, 2.9, auto, 4x4...
I have a problem with my truck when I 1st take off when the truck is warm. Sometimes it happens when its cold as well but not if I let it warm up..
If I run the truck and shut it off, It fires right up (as usual) but about 30 seconds in, especially if I get in it and go, it starts to lope like crazy and stutter. It has yet to actually stall out on me but it chokes itself out and then it revs up and all is well.
I wish I could pull codes but I cant since someone cut the return signal wire to my diagnostic plug. (still looking at that one..)
I've replaced the Engine coolant sensor, thermostat (unrelated of course), 02 sensor and thats about it.
I just went outside and I pulled the lines from the Fuel Pressure Regulator and it smells like gas, strongly. No gas is in the lines but it does smell like it. I cycled the key a few times to see if I could get a drip. The line to the brake booster smelled of gas and so did the line going to the MAP sensor as well. The oil *might* smell of gas but its faint. Even the throttle body smells a little of gas....
Any ideas? I was thinking maybe it chokes itself out or loads up on gas @ start up but the reason why I dont notice it when its cold is because I let it warm up for a minute or two before I take off...I might have to do that when its warm to verify...
Dont know if its related but recently it has stopped to raise RPMS when I put it in part..maybe the Vac. mod. on the Trans?
