High idle cause found (pic)
fivestring
1987
I just bought this 87 2wd Ranger. It had the TPS disconnected and a lot of other problems needing attention, including missing vac lines, etc. But it did run, albeit with a very high idle and not very good acceleration or performance.
I plugged in everything I could find that was disconnected and after reading a little on high idle issues on TRS, I tried disconnecting the iac and setting the idle to something near normal, which it did just fine. OK. I have a bad or dirty iac.
I removed the iac today to clean and test it and this is what I found....
2014-04-03093833.jpg.html
The gasket was installed just as you see it here. Lolz. Not even close. I believe there may have been beer involved when this was installed.
I want to see the pic.................
Thanks fastpkr. I was in the middle of editing and had to return to work.
No problem. Can you do anything on your end to reduce the size? I didn't see any obvious way to use a thumbnail as the image and link to the full size. May have just missed something when I looked quickly this morning.
[ URL=http://i1207.photobucket.com/albums/bb464/five-string01/2014-04-03093833.jpg ][ IMG ]http://i1207.photobucket.com/albums/bb464/five-string01/th_2014-04-03093833.jpg[ /IMG ][ /URL ]
^^ That code aught to do it if you remove the spaces inside the [ ]
Thanks, that's the right code. Not sure why I couldn't find it earlier.
