your barely even taxing the factory alternator with your setup.
your lights are 390 watts total. your horns are 190ish. lets say the average aftermarket "big" stereo draws 500 watts RMS. thats just over 1,000 watts or just 77 amps @ 14 volts. your factory alternator is 95 amps, leaving 252 watts for everything else (that is, if you were to drive around town with the stereo cranked, lights on, and horn blaring...which i doubt you do alot).
if itd make you feel better, you can swap in a 130 amp alternator from anexploder, but it isnt necissary.
