rranger
I just did a TCC lock-up solenoid, and now my truck has a huge hesitation befor it goes into gear, what could it be??? The valve body gasket the one thats thinner than paper looked old and had small cracks can this cause hesitation before it goes into gear?? i really appreciate any suggestions); What Im basically wondering I guess is what are the most common causes of hesitation befor it goes into gear, you know you have to bring the rpm way up to get it to go into gear, if you put it in drive and wait it will take a while but it will go into gear than you can drive. but its really bad to have to rev way up every time I brake, just to get this trans in gear. Does the A4LD in 1985 have a vacuum line running to the transmission from the carb or intake manifold???
Again thank you very much!
