Help with tranny swap, what fits?
85Diesel
Hi there,
I have an 85 Ranger reg cab, short box 2.3L turbo diesel with manual trans (2wd). The trans lost 2nd gear and I am wondering what will swap. I hope I can find some more info here as I have already looked at the Tech section.
I have two choices:
1) use TK 5spd 2wd from my donor 86 supercab long box 2.9L??
2) buy a donor truck that I could use all the 4x4 gear from the clutch to the wheels and bolt on. (from what I can find, I would need the FM145 transmission???
I hope someone can help me with this please!
Should have a Mazda m5odr1/ hd do you still have a door code?
If your looking for a straight swap, the Toyo Koygo will be better off than the FM145, as it is able to withstand more Torque and demand. The Toyo Koygo is a pretty good transmission.
The FM145 is what i have in my ranger. And i have a 87 ranger 4x4 that originally had the old cranky 2.9 but swapped to a 4.0. FM145 is a good trans too, only problem i have ever ran into was when i rebuilt it, i had to get an update kit for 5th and Reverse because one of the teeth off the gears broke off to a manufacturer fault, the update kit fixes this. Only thing i have ever ran into with it. Hope this helps! Let me know what you choose! Good Luck!:beer:
The original post was from 2007 :)
Hope he has done the work by now
Jesse posted so it came back to life :)
