themaxx69
First off I'm not sure what kind of lift this has. It has james duff dual shock mounts with extended radius arms, but the coils I was told looked like superlift or skyjacker, not sure.
I have 33's and they rub a bit on tight turns.
Problem is the front end. I had ball joints, bearings, steering linkage, u joints, brakes, rotors, and some other stuff replaced a couple years back. Since then the truck hasn't seen much driving. But, because I'm a dumbass, I never got it aligned after all that work and at some point the tires started tilting inward (see pictures). The passenger front was leaning in real bad and I found one of the bearings was destroyed and the rotor was toast because of that. Replaced both, but if you look at pics something isn't right.
I took it to get it aligned at Desert Rat(not going there again), and they wouldn't even align it. They gave me some bs about everything, but couldn't tell me why the front was tilted in so much. They said I needed tires, leaf springs, bushings, ball joints, etc. They said MAYBE moving the driver traction beam down to the lower bolt might help. They also said it needed alignment cams, but that those wouldn't correct the major tilt problem.
I took some pics and put them on photobucket. You can click this link or search themaxx69 in people on photobucket.
http://s263.photobucket.com/albums/ii121/themaxx69/
I used autozone ball joints, wondering if I should have got better ones.
Ohh, and when you lift the front end, it straightens out. Don't know if it's the ball joints or what. Also, even after I replaced all that stuff years ago, the front still tilted in a little. Alignment cams, bolt position???
Any help would be much appreciated.
