help with fitting 31's
yes it will...
l8r, John
thanks. i think this is what i'll do. just by looking at the truck it seems like it would fit a set of 31's under the rear. the front sits 3/4" lower than the rear so if i level it then it just might work.
^^^ bump ^^^
I have the same truck and problem, expect mine's a manual transmission. I'm curious what you ended up doing with your truck....
I have just a couple washers under the front of my truck and my 31s fit with no rubbing. It depends on the offset of the wheel more than anything, If u use the stock 15 x7 wheel it should fit stok. If its a farm truck and u want to lift the rear, throw a extra leaf or 2 in the pack, good to go
