jjpp250
- Oct 22, 2007
- Central, CA
- 2.8 V6
- Total Lift
- 5.5” + 2.5”
- Tire Size
- 32/11.5/15 33/12.5/15
this is my first time working on a 2.5l 8plug ranger. I was changing the powe steering pump, plugs and wires and 1 coil pack. Well I have work on engines for years so it not that I am new at all. First off every time I let off the throttle the truck wants to die. I checked for vac leaks crossed wires every thing I I could 2 times. Second I have a worse whining sound in the pump than before. I have jacked up the front and bleed the pump for for some 10 min or so. I am going to try to bleed it a little more with someone to watch for air bubbles.
