aggoodin
I went through the alldata and got the pins of everything else I need but there is no mention of a tach signal in the diagrams. I read somewhere that the coil pack ignition vehilces pull this off the crank sensor. I tried this. I got a signal but it certainly was not right. My RPM's read max and went down when I goosed it.
I can't find a voltage on the gauges that varies when I step on the gas either!?
What the heck drives the tach on the gauges?
And where on the PCM can I find the right signal?
(I am putting in a safc I had laying around the house)
