mkpecor
- Dec 27, 2007
- Age
- 43
- black diamond W.A.
why do you need to change dashes and steering colums? cant you just put the motor in and be good. thanks mike
No, 2.9L bottom ends that have had proper oil changes and have been taken care of last TWICE that. At least. Including the timing set; it's not a 1970 SBC.if the bottom end has 168k it probabley needs to be freshened.. check you compression in all the other cylinders but the bad one.. do an average.. you at least need a new timing set. they last usually 125k.. at 170 k you probably got a nice ridge but will have to check once it's apart..
Umm, why the HELL don't you Magnaflux it BEFORE putting new hardware on? You can very easily Magnaflux bare castings.As far as heads goes.. why put on a junk yard special.. by the time you go thru them new valves. springs etc.. you can have 200-300 bucks and then have to pay for magnfluxing them just to make sure..
