extremely easy did my t-case in about 2 hours on the ground with out even jacking it up. did the hubs when i changed my rotors and bearings (check these while your at it, i had a bearing going bad and didn't know it) didn't take 30 minutes a side.
be careful of your donor. check the u-joint sizes on both your vehicle and the donor different years can be different sizes, same with transmissions the sifters are different for different trannys. the front drive shaft can be different also, most 1350's have slip yokes built into the case, new cases(mostly 1354's, some 1350's) have a front fixed yoke with a slip in the drive shaft. you should have a slip joint in your t-case stock
the process is simple, remove the skid plate, 4 bolts on the rear drive shaft, same on the front (remove at the hogs head pull the slip joint out at the t-case), then 5 bolts on the tcase itself. be careful the tcase can sometimes hang on the alignment pin. install in reverse.
the hubs involve removing all the auto hub guts on the spindle and replacing them with manual hub nuts (sold as a conversion kit from warn and mile marker) this will require a torque wrench and special hub socket there is a good write up on this in the tech library
any other questions or want more details just ask
