danny k ply
Help please I have a 93 Ford ranger 4.0 I put a new fuel pump new fuel pressure regulator new fuel filter I have a new ignition control module I checked the fuel pressure at the pump and it's got 70 PSI when I go up to the fuel rail and check the pressure it has around 27 to 30 PSI when I start the truck it idles great but when I accelerate in neutral just revving the engine it gets around 4,000 RPMs it shuts off like you turned it off with a key if you have it in gear and driving it it'll shut off at 2,000 rpms like you turned it off with the key I've also put new injectors in I've checked them with a stethoscope to make sure they're working I hear them clicking new plugs new wires just about every sensor well actually every sensor on the vehicle I have changed any input on this would be greatly appreciated
